light on the cruise button comes on but the light in the gauge cluster doesn't and my controls won't work, b4 i get the try searching reply i have used a couple and they didn't tell me much, if someone has a specific phrase they typed in that helped the search results bring better answers it would be appreciated
cruise probs
Check your vacuum hoses... Not sure if this is why your cluster isn't showing, but if the cruise control isn't even engaging, you might want to check and see if that is the case. The cruise control system uses the vacuum hoses to work properly, and if there is a leak somewhere, it could be a really cheap fix.
In addition to all that was mentioned above, keep in mind that your Cruise Control Unit will not engage Cruise Control if your Vehicle Speed Sensor (VSS) is either not working or has a bad connection with the Cruise Control Unit.1997 Honda Accord EX-V6:
Originally posted by James MatteuYou have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
