Rpm lag
    Rpm lag
    I dont know how to put this i have a 92 cb7 4 door 5spd with a JDM f22a1 in it but the car for some reason doesnt really pick up speed in lower rpms I guess a lag.. but in a higher rpm it flys.... would a intake be a solution??...
    MR : http://www.cb7tuner.com/vbb/showthre...ght=CB7+R3ason
    Originally posted by quaidum
    you being able to see four blocks down the road is resulting in someone not being able to see 5 feet in front of them
    good job, just what the world needs more inconsiderate drivers
    jdm f22a1? ummmmm well for one, all JDM motors do not have a number after the motor stamp. Did you swap it in? No factory Honda motor was made to have power/torque in the lower rpms. Pretty much unless you have a Big V8, a Supercharger, or nitrous, your not gonna have much power in the lower rpms especially under 4k rpms.
      its a 50k jdm engine i know that.... pretty much theres nothing i can do right
        is it vtec motor or no? Dual over head cam or single? If you look right where the transmission mates to the motor, theres a plate that has a stamp of what motor it is. To the left of your motor mount if its still there. Its hard to tell exactly whats goin on and if its normal or not when im not even 100&#37; sure what motor it is. Take a picture if you can. I'd love to help or give info, just all the info is not there for me to explain.
          hey its non vtec single and it says on the block f22a
            So it's an F22A. Not an F22A1. The JDM F22A is closer to the F22A6.
            Anyway, check your ignition timing. I'm willing to bet that it's way off, causing you to have a soggy bottom end.
              if your feeling some lag on take of your diiz might be to far back......mark where it sits now an advance it a lil about a hair try it until you feel the car is running better not to much cuz you can do more damge then go if you go to far if the car is still not responding then return to where it was at you might have other problems
                Or he could use the proper tools to adjust his ignition timing...
                Why must people insist on halfassing things?
                  because posts are easier to acquire that way and much less typing is involved
