ok i know what could happen to your vtec if it was wired direct and that it can burn it..but i wanna know if out the two plugs do i wire two wires to power and one to ground??this is not for my car i have a friend who wants wire his direct cause he doesnt have enough for a ecu and he wants it..lol
VTEC question
wait.....so he wants to do something that will cost him money to fix when hes screws it up cause he cant afford to do it right knowingly it will cost him double to fix and do right later.......? If money is an issue, he needs to be patient and get the ecu and run it correctly. With vtec engaged at all times it would suck anyways....no torque on the bottom end much less already a d16 w/ no torque to start....
Here's one, at least tell him to get one of these for the time being. Pretty sure it's a simple add on regardless of ecu, but research it for yourself before having him buy it.
http://cgi.ebay.com/ebaymotors/VTEC-...Q5fAccessories
Originally posted by chrischhorn View Postaccording to the wiring diagram they show on that page, you still need to have a vtec ecu as you need to wire it into the ecu....all that does is let you change the engagement point of vtec without having to socket and make a chip to change it.
Originally posted by deevergote View PostSo he doesn't have enough for a $50 ECU... but he's willing to damage his engine? I'm sure that costs more than $50...
Sounds like your friend is a certified r-tard.WHEN LIFE PASSES YOU BY...DOWN SHIFT...
Sounds like your friend is a certified r-tard.what shall not
kill you shall
only make you
STRONGER
