h22 really lagging!?
    hey, so i have a h22a and i just finished my swap, and when i floor it, its really lacking power and even when vtec hits. doesn't have much power at all. i have no vacuole leaks, no cel. what kind of things should i check for?
    P.S ( its not me complaining about the hp of the engine i know what it should have and its really not doing anything. something is defiantly not right) thanks
    H22 cb7:
    http://www.cb7tuner.com/vbb/showthread.php?t=133482
    cb9:
    http://www.cb7tuner.com/vbb/showthread.php?t=187076
    dd cb7:
    http://www.cb7tuner.com/vbb/showthread.php?t=203058
    timing belt adjusted correctly?
    are you even able to get to vtec without issues?
    MadLab Racing
    Southern Maryland
      ya goes to vtec like it regularly would. just theirs no power!...
      i did change timing belt and im pretty sure its right, but if off by a tooth, it could do it..?
      H22 cb7:
      cb9:
      dd cb7:
        Also forgot to include the engine passes smog.
        But it definately is a wierd issue.
        The CEL comes on at 3100 RPM for code 41
        But usualy with an O2 code, the engine still runs fine (atleast for me)
        Your man for wiring solutions!
        CB7Man's Coupe H22 Swap
        CB7Man's Sedan Resurrected From The Dead
          If the timing is off by a tooth, that could definitely do it.
          A bad o2 sensor or a bad MAP sensor could also potentially cause low-end bogging. I believe my car has a problem with the o2 sensor, and only way I was able to temporarily fix it was to richen the fuel mixture (not an option you have available to you right now).
          Check your CEL for codes. Expect to replace that o2 sensor with NTK/NGK or Denso (not Bosch).
