When I hit my brakes my horn sounds
    like the title says when i hit the brake pedal on my car my horn sounds. My car wont get off parking either with the brakes pressed nor do none of my brake lights work. when i take off the fuse under the hood n put it back in it works like normal. i was wondering if anyone else has had this problem n wether its a bad ground or relay?
    so do you press the horn to brake?
      no when i hit the brakes the horn sounds like if I am pressing the horn
        Your brake switch grounding to same ground as horn??.....odd but possible. Investigate.
          That's awesome.
            Nice...could you imagine if that same "horn" button were for nitrous?
              Why couldnt it?
                I had a similar problem once... my horn kept going off and I had to disconnect it (in the rain in traffic ) to keep it from honking constantly. I don't remember fully if it affected my brake lights or not-it sure seems like it did, but it turned out to be a short in the wiring for the horn itself. some of the insulation had rubbed off and it was grounding to the chassis. Now that I think about it, I think my brake lights were staying on... because I think I changed my brake light switch thinking that the little rubber stopper in it had broken/fallen out and the switch/button was just going through the hole. I'm not 100 % sure, but I think the ground for the horn and brakes are somehow tied. I remember changing those 'chips' in the brake lights and following the wiring into the parcel shelf area... and ultimately re-shrink wrapping the wires in the drivers side horn harness. I hope this helps, but break out your repair manual if you have one and go from there. Consult the wire diagram...
                  Originally posted by JDMdreamz View Post
                  I had a similar problem once... my horn kept going off and I had to disconnect it (in the rain in traffic ) to keep it from honking constantly. I don't remember fully if it affected my brake lights or not-it sure seems like it did, but it turned out to be a short in the wiring for the horn itself. some of the insulation had rubbed off and it was grounding to the chassis. Now that I think about it, I think my brake lights were staying on... because I think I changed my brake light switch thinking that the little rubber stopper in it had broken/fallen out and the switch/button was just going through the hole. I'm not 100 &#37; sure, but I think the ground for the horn and brakes are somehow tied. I remember changing those 'chips' in the brake lights and following the wiring into the parcel shelf area... and ultimately re-shrink wrapping the wires in the drivers side horn harness. I hope this helps, but break out your repair manual if you have one and go from there. Consult the wire diagram...
                  wow man please do not do that again, (font size one=bad)
                  _
                      g00d times man..humm d0es the fuse keep p0pin after u replace it?
                      my new turbo build
