have noticed car is slightly boggish when starting from a stop. i was running bout 1/8 tank of gas and took a corner and the car died. it sounds the same wants to start but wont. i tried adding more gas and jumping it because i know i have a week battery. Im thinking fuel pump but if any help would be great its my only car and i do the work my self i will go buy parts soon just hate replacing good parts.
need help fast car just died! fuel pump?
Replace the cap and rotor. Clean your battery cables and terminals (I've had corroded and loose connections cause a no-start issue, even though it had enough power to turn the motor over.) Check all grounds... make sure they're clean and tight.
If the problem isn't fixed by that point, look to the ignition coil (90-91 is internal, 92-93 is external). If you replace that and STILL have no spark, replace the ignitor. A failing ignitor USUALLY results in erractic tachometer operation before it completely quits, so unless you experienced that, the ignitor is less likely to be the culprit (but still entirely possible.)
I just had the EXACT same thing happen to me yesterday. Went to go make a right turn from a stop and while accelerating she died. I put my ear to the fuel pump and had a friend turn the key. I didn't hear it kick on, but maybe they run silent?
I'm going to check for spark today when I go out by her today. She's still dead on the road and I don't have money for a tow.I <3 My Honda CB9!
My Hondas
1992 Integra LS Coupe (Sad story...)
1995 Civic VP Coupe (Traded for->)
2002 Civic EX Coupe (Traded for->)
2006 Acura MDX (Long story...)
1988 Accord DX Sedan (Donated to a friend)
1992 Accord LX Wagon (Sad Story)
