How to Change Rear Brake Pads??
    Hi,
    92 ex.. i need to change my pads on the back end of my car.. how do i do this? They are disc right? any special tools or anything?
    A step-by-step would be great, since i've never done this before!!
    Thank you!
    92' Ex - Needs work, but hey! It runs safely
    91' Lx -Car vs IDIOT.. R.I.P.
    RIP 92' Lx... Car vs Concrete.. Car lost.
    I believe the rear brakes are drums not pads, I don't know much other than that sorry.
    Current:
    2007 Acura TL Type-S 6MT KBP
    Past:
    1992 Honda Accord EX-R Sedan - RIP
    1991 Honda Accord EX-R Wagon - RIP 10/14/2010
    Words change lives. You just got to choose the right ones.
    Instagram: @CB7Nub
    Check out the more active "CB7Tuner Canada" Facebook group for CANADIAN members ONLY.
      You need to unbolt the caliper from the rear. There are 2 bolts holding it. After bolts are gone, remove the caliper of the disc with your hands or a little prybar, it will come out easilly. You'll now have the pads falling in your hands. Put new ones and put caliper back on the new pads. You'll have to turn the piston on the caliper so it will go back into the caliper. You have to do that because your old pads were used so the new ones are bigger.
      hope this helps
        Originally posted by Aries1911 View Post
        Hi,
        Thank you!
        http://www.cb7tuner.com/vbb/showthre...ght=rear+brake
        He has a 92 EX , they're discs.
        1996 Honda Civic LX 2009-2012
        2012 Kia Optima LX 2012-2013
          Do you know how to do the front? if so its exactly the same
          If not
          Unbolt the caliper from the bracket
          Pop out 2 old pads
          Put in new pads the same way as they were removed
          Press and turn the piston back in ( its different from the front because it has a mechnical parking brake on the caliper )
          Put the caliper back on and enjoy your new brakes
          Rear brakes are a tad bit harder then the front.
            Ive heard about a special tool to put the piston back in.. do i need that? if so, where can i find one?
            What about the spacer thing? i guess it pushes the caliper out so it fits on the new pads?
              You can use use a C clamp
              The rod for the parking brake needs to be screwed back in and the piston needs to be pushed in. So you need to push the piston down on the rod and tun it at the same time.
                I used a large flat head screw driver to screw back in my pistons.
                MRT
                  I felt like being generous, a vid tutorial for those visual learners:
                  Part 1
                  Part 2
                  Part 3
                    That guy has the best DIY videos EVARRRRRRRRRRR
                    MRT
                      yeah he just made this timing belt video, thats probably the best hands down. But he got smart and is charging 10 bucks for the download off his new website lol.
                        easiest way to turn the piston the tool you can find at a honda dealer but is to expensive flathead screwdriver is cheaper
                        what shall not
                        kill you shall
                        only make you
                        STRONGER
                          Losiracer2: Thats EXACTLY what im lookin for! Thank you!!!
                            I found the tool at Harbor Freight in the Automotive section. It looks like a cube, that accepts a 3/8th's ratchet, that has pins of different sizes all over it. Cost me a total of 4 dollars I think.
                              this is the tool Losi is referring to:
