OK....Well now....
First of all, I want to know if I should cut the bumpstops in half, or down to like an inch and a half due to the 2" drop the springs will give the car. Or should I just cut them off entirely? I was considering just cuttin' them off completely...but wondered if maybe they might serve a better purpose than none at all and thought maybe I should just cut them down to size. I was thinking about an inch and a half. I can't find much on it here on the site. The DIY suspension install mildly covers it, and another thread I found and post by accrdpower says
"...the yellow spongy things are called bumpstops....i just took mine out. i'm riding on the struts anyway."
So uh, maybe just take them out completely?
Second, I can't get the DAMN TOP HATS ON THE FRONT STRUTS...I do NOT want to use my impact gun to rattle them on, that sounds like a bad idea. My brother said that could potentially heat up the struts and risk damaging them leading to a leak. I do not want that. Yesterday I put the strut up in place, attached the top fork bolt, and then tried attaching the bottom fork bolt but couldn't get the damn thing to line up.
I tried using the oem jack to push it up in to place, but I don't have anyone to help pull down on the upper control arm to get it to line up...It's damn near impossible. but, with the jack underneath it, under pressure it seems to stop the strut from spinning and I was able to tighten the bolt down some...But I ended up taking it back out cause I realized the whole bumpstop issue....
ACHTUNG please!! I really need some wisdom on this whole thing!!!
