1990 Sport light and stuck on 2nd
    Today, I took off in my 1990 Lx, and the sport light was permanently on, whether or not the button was pushed in. Also, it was stuck in 2nd gear. It would take off in 2nd, and stay in 2nd. What I do is I put it in 1st, and then shift into 2nd. But it doesnt shift into third, or fourth. What can be the problem? Thanks.
    The S light is the diagnostic trouble code for the 1990 and 1991 accords
    It being on all the time means there is a problem
    Your transmission is in 2nd gear because it is in limp mode because of some sort of fault
    Try to pull the code for the S light ( same way as a check engine light ).
    If the light does not flash then its most likely a faulty TCU
      Well, sometimes if I turn off the car and turn it back on, it'll go away. Then, after a few seconds of the car being on I'll hear a clicking noise coming from under the shifter, and the light will come back on. I have had the S light stay on before, but it never affected the way my car shifted, so I never thought nothing of it. And it would always go away. But now, it always does it.
        Because something is broken. Pull that code, find out what it is, and replace it. Your car is trying to tell you what is wrong.
