what are the benefits of having a pt6 over having a pt3?
benefits between pt6 and pt3
The pt6 will run a little richer and you'll lose the speed limiter. If you want to swap ECUs for more power, get a p12 from the f22a1 Prelude. It's the only difference in the driveline, and the Prelude came with ten more ponies than the Accord.
If you want to know more, do an advanced search for "p12" in the titles.
http://www.cb7tuner.com/vbb/search.php?searchid=5399407Last edited by visualpoet; 04-15-2010, 06:15 PM.
Originally posted by visualpoet View PostThe pt6 will run a little richer and you'll lose the speed limiter. If you want to swap ECUs for more power, get a p12 from the f22a1 Prelude. It's the only difference in the driveline, and the Prelude came with ten more ponies than the Accord.
The f22a6 makes a bit more power than the f22a1 that came in the Prelude due to the different cam, better exhaust manifold and dual runners on the intake manifold. I thought the pt6 had a better tune for the dual runners.
Originally posted by mgcshroomz View PostThe f22a6 makes a bit more power than the f22a1 that came in the Prelude due to the different cam, better exhaust manifold and dual runners on the intake manifold. I thought the pt6 had a better tune for the dual runners.
The ECU alone from the f22a6 (the pt6) isn't going to give you as much power as the p12 on a stock f22a1. You need the IM, cam, exhaust manifold AND the pt6 in order to make 5 more hp than you get from the p12 alone.
