after 15k to 2k it goes good but still has a little slight lag to it tps was bad and i changed the throttle body now it idles sort of high if i lower the idle to where it should be it lags worse on start up so i have distributer advanced as far forwrd as it can go idk whats going on
f22 series motor lagging on takeoff
and yesterday when i got to the baseball field for my nephews game i slowed down and went to park and it started sputtering when i hit the gas so i sputtered into a spot and cut it off until the game was over then i went to get in and go home and it didnt really do it as much and oh yea i got oil in my antifreeze not much but no antifreeze in my oil meaning oil aint milky
fuel injector leak? Check the air filter, wouldnt make much of a difference but still helps to clean. Check fuel pressure, and is there any sort of short in the ignition system? I once had a short across my dizzy rotor that caused a whole hell of problems. Moisture in the gas tank? could be because the dizzy is to far advanced and is putting too much fuel in and not burning it off til 1.5-2K rpms.
Originally posted by deevergote View Postyunglos2008, if you make one more thread asking this question, or hijack someone else's thread again, you will be banned from this site.
First, check your basic tune-up items (plugs, wires, cap, rotor, air filter, fuel filter, etc.) and go from there.
Most likely, its something like that.
If it doesnt go away afterward, then check your timing/etc.
If you have bosche platinum plugs, get rid of them by throwing them at whomever told you they were the best plugs for your car, and replace them with NGK or Denso ONLY.'92 h22 CBMRT-->http://www.cb7tuner.com/vbb/showthread.php?t=158641
UNICORNS=donkeys with plungers stuck to their faces...
Originally posted by h22cb719 View PostFirst, check your basic tune-up items (plugs, wires, cap, rotor, air filter, fuel filter, etc.) and go from there.
I spent 2 days trying to help diagnose a problem with a guy's VTEC once, and he neglected to tell me he was running a non-VTEC ECU. Make sure everything is as it should be... then we'll figure out what isn't working.
And for god's sake... type so we can understand you! Punctuation, spell check, general coherency of your statements... You expect us to take the time out of our lives to help you with your car, how about you take a little time in typing your question so we know what you need from us?
sorry man i didnt have any idea i hijacked someone elses thread i am new to this place and was in desperate need of help and still need help i accidently posted twice not realizing it i do appologize for it tho wont happen again i was just going to where there was people chattin and figured i would ask questions
