H23 Intake manifold
    H23 Intake manifold
    what is a h23 intake manifold? what does it? Pros cons? i appreciate it
    its the intake manifold of a 92-96 prelude SI i believe. its better than our IM and it bolts right in, you also need the TB. AND you need the IAB box out of a f22a6 and the ECU from that same car to make it work(open secondary runners).
    i short words its a performance part for your car.
    JENNA 91 LX
    RIP 12-11-09 - 12/06/10
    JANE 99 Infiniti i30
    2-9-11 - current
    "Life is simple, you make choices and you don't look back."
      what kind of performance do you get and what is the over price for all this?
        It gives a noticeable increase, I'd say from going from an F22A1 to this manifold setup, about 10-15 hp. Because it has 8 inlet ports instead of 4 and the throttle body is about 4mm bigger in diameter. Well I guess you can say the F22A6 manifold has the same bottom runners, but the plenum volume is also 2-3x the size of the F22A1's. Basically you're engine will breath MUCH better in the upper RPMs
          better throttle response and few ponies. It depends where you buy it from,
          in a junk yard about $100-150 for everything.
          JENNA 91 LX
          2-9-11 - current
            Alright ill just ask this here.
            I found one myself at the junkyard
            I got the upper half off and was trying to get the lower half off
            I have all the bolts bolting it to the engine block out but it wouldnt come out
            What was i missing?
              there is a support beam type thing underneath it thats bolted the IM and the block
                Is it hard to remove? Im going back tomarrow in the rain to get it off. Man i want this intake manifold so bad lol.
                  What was i missing?
                  The one that goes to the support bracket on the back of the block that connects to the runners?
                  3 CB's gone....
                  1 WK Overland....
                  Still miss the CB though......maybe one day.
                    Yes
                    Sorry OP for a hijack but this could come in handy for you too lol
                      no its easy, but you need a long extension to get to it from underneath the car. I think its a 12mm bolt.
                        it depends if the car is off the grownd.......if its lifted up you can get underneath it and BAM the bolts are right there, you cant miss um'
                        Then you have yourself a H23 IM!
                          yea the strap/support that goes under the IM to the block. its held on by a 12mm bolt.
                          IMO for an all motor car its best to run the A6 runners with the h23 upper plenum and TB because the A6 has longer runners which help with torque especially when combined with the h23 plenums increase volume over the a6.
                          to the OP its not 100&#37; nessassary to run the ECU and the butterflys can be run open at all times and added power will still be utilized. I really dont see the point in controlling them when they are open at full throttle anyways.
                          member ride thread
                          DIVULGE MOTORSPORTS
                            you can reach it under the intake manifold with a socket and get it, no need to get at it from all the way under the car.
                            member ride thread
                            DIVULGE MOTORSPORTS
                              im so happy now i cant wait to go get it lol. So its better to make a hybrid between the a6 and h23 intake manifolds? I have an a6 right now
