Ecu???
    Ecu???
    Hello To Everyone, I Am New To This Site And Wasnt Sure How To Use It But Now That I Do I Have A ??? About Ecu's. I Am Turboing My 91 F22 Auto And It Has A F22a6. I Did A Little Research And I Was Told I Should Run A Pt6 Ecu? Is That The Best Ecu For My Setup Or What Would Work Better?
    The PT6 is the ECU that came stock with your F22A6.
    If you are going to turbo your best bet is to get one that is chippable so you can datalog, tune, etc. I'd say the most common is the P06 (out of 92-95 Civics).
    Click Image for CB7Tuner.com Beanies, Decals, & Keychains!
      For turbo, you need to have an ECU that can be modified and tuned (such as the P06 mentioned above). You cannot simply run a stock ECU. Tuning is the most important part of a turbo setup (assuming all your other parts are correct and reliable).
      And please stop typing in all capitals. It makes your post very difficult to read.
