What to Upgrade Now for FUTURE Turbo Build
    I want to turbo later on but I'm not knowledge wise or money wise. What can I upgrade performance wise now that I can put to use in a turbo build later on in a year or so time?
    Note: Catback system wouldn't work in a turbo build like a Apexi WS2 right?
    Current:
    2007 Acura TL Type-S 6MT KBP
    Past:
    1992 Honda Accord EX-R Sedan - RIP
    1991 Honda Accord EX-R Wagon - RIP 10/14/2010
    Words change lives. You just got to choose the right ones.
    Instagram: @CB7Nub
    Check out the more active "CB7Tuner Canada" Facebook group for CANADIAN members ONLY.
    A cat back system would work, you just have to consider restriction. A turbo car needs to push out a lot more exhaust, so the smaller the piping, the more restriction fighting against the turbo. If you're looking for a lot of power and reliability, building the motor for turbo would be your best bet. Just curious, what motor are you going to be using?
    '92 Accord DX
      The Apexi WS2 is 66mm, I believe... about 2.33". Fairly small, but for a mild turbo setup, it will work. 3" is usually the size to go for, but most don't really bother.
      A CAI makes a good cold-side charge pipe.
      If you plan on boosting the stock block, some ARP headstuds and a new Honda head gasket would be wise.
      A Walbro 255lph fuel pump would be a good choice.
      If you want to learn how to tune an ECU yourself, then getting a P06 and the necessary tuning tools would be smart. Mess with tuning BEFORE you boost. You're far less likely to blow something up with a stock-ish motor!
      New mounts from ESP would be smart, since you'll be removing your front torque mount (you could always talk to ESP about making a front mount you could use as well... but that's not quite as necessary at the moment)
      A new clutch would be smart as well. The turbo will eat your stock clutch very quickly.
