Alright I'm posting this in this section too because its hardly getting any views in the cd5 section and I'm in a bit of a hurry to figure this out.
On my 95 accord I'm trying to figure out which settings cause the cruise control actuator to receive power. I'm trying to use the connector to the cruise control actuator to provide power to something else under the hood that preferable will switch off if I go below 25 mph or hit the brakes. My thinking is the cruise control is already set up for that. Now I'm not sure if the cb7's system is the same but the actuators look similar so maybe you cb7 guys can still help me out.
For testing the actuator it says to connect battery power to the white wire on the actuator harness and ground the others. So is the white wire the only one that gets voltage and the other three just have the connection to ground switch on or off?
I'm really just interested in which wire will have power when either just the cruise switch is on or when the cruise speed is set. Any help is much appreciated.
