I just bought this cheap ass CB and removed my valve cover to replace the gasket and discovered all this bullshit gunk in my shit. What the hell is that? And how in hell do I get it outta there? I've already drained to oil and whatnot. Can I seafoam this shit? Please help a brotha out.
What the hell is this?
Originally posted by BabyD91904 View Postjus looks like sludge build up to me if it was me i would take tha head off and clean it out real good b4 puttin it back on.
Originally posted by Nerocb7 View Postmetal shavings??? or maybe the last owner added some oil leak repair sh** idk was the car running fine before you saw this???
Originally posted by HardInThePaint View PostCan I seafoam this shit?
Seafoam is meant to clean out your intake manifold mostly, it wont have any effect on internal engine areas like under the valve cover (although seafoam may remove a small amount of deposits from within the actual combustion chamber). All that "junk" is just engine oil sludge which normally accumulates over time (although can accumulate alot quicker, if the owner gets lazy on their oil changes). Using really cheap oils (which contain less additives) and/or conventional oil also contributes to sludge build up quicker (synthetic oil is made up of uniform hydrocarbon chains, and generally does not contain as many "bad" chains of hydrocarbons which form sludge easier).
The only real effective way to remove all that sludge would be to remove the cylinder head and have it hot-tanked (or acid washed, whatever you like to call it). Or if your on a budget, you can remove the cylinder head and scrape it out and use brake-clean or carb-clean to wash away the remaining sludge. I wouldnt reccomend trying to scrape away the sludge with the cylinder head still on the engine, because the little chunks you cant pick out will eventually get circulated around the oiling system and can clog small passage ways.
They also sell engine oil "flush" kits, that you add to your engine oil, which supposably loosens up sludge and deposits, and removes them. Only problem is all that sludge has to go somewhere, and will most likely clog your oil filter or get stuck on the way. I wouldnt reccomend any "mechanic in a bottle" type fixes. Your best bet is to remove the head and go from there, but if its not causing any problems (yet) it may not be worth your time.Last edited by ON_N20; 04-04-2010, 08:24 PM.ON_N20Nitrous = Been there. Turbo = Now. Nitrous + Turbo?... LOADING
Originally posted by HardInThePaint View PostYeah I will put oil back in it and pour seafoam in the crankcase and then do an oil change. Hopefully it'll get that sludge up outta there.
By the looks of the picture your engine seems to have alot of miles on it, I wouldnt worry about the sludge for now, it may cause more harm trying to get rid of it, than to just let it be at this point. Your best bet at this point would just be to focus on doing regular oil changes, and wait for a future engine rebuild to get rid of that sludge since there is so much there already.Last edited by ON_N20; 04-04-2010, 08:43 PM.ON_N20Nitrous = Been there. Turbo = Now. Nitrous + Turbo?... LOADING
do an oil change. put 3 2/3 oil and the rest kerosene. run the car for a few min. change the oil, drive for 500 miles. then change the oil again.... that should clean it up really good. then check if it is metal shavings in there or if it just sludgeare we there yet are we there yet are we there yet
