What the hell is this?
    couldn't he just run transmission fluid in there since they have more detergants than regular motor oil? just run it for a little while and then do a drain and fill with cheap oil for a few days.
      Originally posted by alb_accord View Post
      do an oil change. put 3 2/3 oil and the rest kerosene. run the car for a few min. change the oil, drive for 500 miles. then change the oil again.... that should clean it up really good. then check if it is metal shavings in there or if it just sludge
      but do the first oil change when the car is warmed up so the oil temperature is high enough that the oil filter's bypass valve is not activated by excess oil pressure from thick (room temperature) oil. Also, do an oil filter change after you are done.
