accord wont start, need a list of things to check
    my car has been pretty good to me, is about to flip 200k.
    but..
    today, getting ready to get on the freeway near my house, i notice my car decelerating instead of accelerating.. i pull off and turn off the key.
    the starter turns, but doesnt sound normal.. like there is no way in hell its going to start, just a quiet cranking sound.
    so i check obvious stuff, plug wires, clips near my dizzy, batt cables, ecu fuse... all seem ok.
    I had my 1.5 year old daughter with me, so i didnt want her sitting in the car too long so i walked her back home (1/4 mile or so)
    things im going to check when i go back over there:
    listen for fuel pump when i turn on the key, (if not, ill pull the relay)
    check for CEL codes (if there are codes ill have to look em up)
    pull a wire+plug, and check for spark (if no spark, ill swap out igniters)
    anyone else think of other things to check on my first trip out?
    I'm hoping to make as few trips as possible.
    is it spinning faster than normal? if so, you may have a busted timing belt... easiest way to check that is pull your dizzy cap off, and make sure the rotor spins when u crank the engine over, if it does, then the belt is okay, if not, well, i think u know, lol... other than that, i'd say you've got a pretty good list to start with. best of luck and hope u get 'er goin again asap
    91 EX Coupe 5 Speed
    My Ride Thread
    ASE Certified Master Tech Since 2005
    That's like watching a guy stick his head up his own ass. Impressive... but why?
    Bought From: Quakerjoe , MikeW
      Start here
      http://www.cb7tuner.com/vbb/showthread.php?t=144944
        [QUOTE=Tippey764;2490066]Start here
        http://www.cb7tuner.com/vbb/showthread.php?t=144944[/QUOTE
        already read it. looks a tad overwhelming.
        im gonna check my timing belt, then check for spark + fuel.
        a buddy of mine's dad (a honda tech) said that if my timing belt in-fact DID break, and i was heavy on the gas, i might have bent some valves as well
          timing belt is toast... cracks between every tooth. broke right at the bottom
            Sorry To Hear, Hope You Get It Fixed Soon, I Know It Can Be Pricey If You Dont Know How To Do It.
              Your engine is most likely toast. Your going to have some bent valves for sure
                [QUOTE=MRFuglyWun;2490072]
                Originally posted by Tippey764 View Post
                Start here
                sorry to hear about the timing belt..i would get a head at the junk yard and have your friend help put it on and hope the pistons are ok
                  here, have a look...... last time i take the word of someone selling me a car that says "the timing belt is fairly new"
                    Ugh.... that makes me want to go check mine right now.
                      about to go "fetch" my car from down the road. hope this whole timing belt thing doesnt turn into a goddamned nightmare.
