91 SE AT plenum install question
    I have a 91 SE AT, so I have been told by a couple of you guys that if I swap for the h23 plenum it will give my car a little pick up. But does it matter if my car is an AT and does it matter if the H23 plenum came out of a AT or 5 sp car. I just want to now if I get the plenum does it have to be from a AT or 5sp or does it even matter. Let me know guys somebody is selleing me one for $25.00 but I dont know if its from an AT or 5sp. Thanks
    Well its not just the plenum you need, you need the larger throttle body aswell.
    The throttle body needs to be from an automatic, unless you want to swap out the throttle plates. The throttle plate is where your throttle cable goes to aswell as your tranny cable.
    Hopefully the plenum and throttle body comes with the TPS, FITV, EACV, and ABV.
    But I guess you could swap the ABV, and TPS and possibly the other 2 from your F22.
    Your going to have fun with the vacuum and coolant hoses after you've swapped it on.
    Then I believe your going to have to widen your intake tube to fit the F22 intake back on.
    I have an H22, and I have the F22 stock intake pipeing on it.
    Your man for wiring solutions!
    CB7Man's Coupe H22 Swap
    CB7Man's Sedan Resurrected From The Dead
      Well they are selling me the plenum,TB and the Intake manifold all in one. Why did you say I will have fun with the hoses?
        The hoses are routed differently on the H23 than with the F22, youll have to mix and match the hoses, or get different hoses from different hondas.
        Ive never done the H23/H22 plenum swap, I swapped engines instead
        However I own both engines and I can tell you the coolant hoses are quite different.
        Once you get to it youll see where everything goes.
        I think theres a DIY on here as to how everything works.
        Here is a DIY for it, the pictures are gone, but it explains alot.
        Here
          hi i don`t think it`s to hard to do,it`s 2 lopes of hoses.i`m going to do it too mine .i`m in prescott. read this http://www.cb7tuner.com/vbb/showthread.php?t=41175
