How to take out DRL (DAYTIME RUNNING LIGHTS)
    Hi guys was wondering since im Canadian...Is there a way taking out the Drl during the day(lowbeams off).....But when night comes and i turn on the lights the low beam turns on.... Just wondering
    VS
    Mercyboy: I rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
    MERCYBOY THREAD:http://www.cb7tuner.com/vbb/showthread.php?t=158241
    1990 RHD Honda accord si CB3 Canada http://www.cb7tuner.com/vbb/showthread.php?t=196287
    MY CB7 ON YOUTUBE: http://www.youtube.com/watch?v=CJID_IxwiNY
    You should search a bit:
    http://www.cb7tuner.com/vbb/showthre...&highlight=DRL
    If i was you i'd try to unplug the relay instead of removing the drl fuse, but the problem is that i dont know if the drl light will light up in your dash . There should be a way to remove drl without having the dash light on....
      Aren't DRLs mandatory in Canada?
        thats what I thought.
          well it is...But ive been working lately...Ive seen lot's of cb7 without drl...SO might as well no have them on
          VS
            Canada Motor Vehicle Safety Standard 108 requires DRLs on all new vehicles made or imported after January 1, 1990. Canada's proposed DRL regulation was essentially similar to regulations in place in Scandinavia, with an axial luminous intensity limit of 1,500 candelas, but automakers objected, claiming it was too expensive to add a new front lighting device, and would increase warranty costs (by dint of increased bulb replacements) to run the low beams. After a pitched regulatory battle, the standard was rewritten to permit the use of reduced-voltage high beam headlamps producing up to 7,000 axial candelas, as well as permitting any light color from white to amber or selective yellow. These changes to the regulation permitted automakers to implement a less-costly DRL, such as by connecting the high beam filaments in series to supply each filament with half its rated voltage, or by burning the front turn signals full time except when they are actually flashing as turn indicators.
            Was taken on wiki. I see cars here everyday that doesn't have drl. I dont think you can be arrested for that but who knows. I'm in Qc, it may change from places to places in canada.
            But i've noticed that the majority new cars does have drl. But not all.
              What if you have HID's in your high beams?
                well i found the realy...I diconnect...but now the promblem is once i turn on the vehicle and i turn on the switch for the lights...it won't go on...so had to put it back....what should i do....??????????
                VS
                  i want DRLs!!!! lol someone told me that its a different wiring setup that lets half the usual voltage to the high beams. i want drls so i can turn on my yellow highs without outshinning my regular lights. pm me if u get rid of them
                  1992 Honda Accord Lx
                  [/I][/I][/I]
                    possibly different fuse box
                      Sorry to bring this back up, but now i have this same question. I've searched CB7 for hours on this but nothing came up.
                      Can one use HIDs with DRL? (The HID kit says no)
                      Has anyone figured out a way to disable the DRL?
                        un-DRL your ride
                        I responded to your PM, but I just thought of something else.
                        Unplug the DRL, de-pin the connector, using some generic two sided connector from another CB, repin the new connector with jumper wires to bridge the open circuits that the DRL leaves behind. You could also cut the wires and solder the ones I have listed below, but I would first test this by connecting the ones below with jumper wires and covering the rest individually with electrical tape.
                        1. Left Highbeam: connect pin #1 (Red/White) to pin #3 (Red/Yellow).
                        2. Right Highbeam: connect pin #5 (Red/Green) to pin #11 (Red/Orange).
                        3. Parking Brake Indicator Light: connect pin #13 (Green/Red) to pin #6 (Brown/White).
                        Note: the wire colors comes from the Helms Electrical Troubleshooting Manual for a 1997 Honda Accord (all models) so the actual colors you see may be different than what I have listed above, but the pin positions on that blue connector should be the same as long as you have a Mitsuba RZ-0126 Running Light Relay
                        Now you have no DRL and can sell the Unit and connector (or pigtail if you cut the wires out) to someone in the US that drools over Canadian stuff.
                        Edit: use 12-14 AWG wire to bridge the Headlight circuits and 18-20 AWG for the parking brake indicator light circuit.
                        1997 Honda Accord EX-V6:
                        C27A4 - 2.7-liter 90º-V6 with SOHC, 24-valves, PGM-Fi
                        MPZA - Electronically controlled 4-speed automatic, 1 reverse
                        ~170 cu. in. / ~170 ft. lbs. / ~170 whp
                        Originally posted by James Matteu
                        You have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
                          bump for updates
                            Originally posted by James Matteu View Post
                            bump for updates
                            I didn't get to try this yet, but couldn't one also ground out the parking break switch permanently which turns the DRL's off.... then pull the bulb on the cluster for Parking Break Warning...?
                            anyone see any issues with this?
