Oil and coolant
    because if you click reply and click the insert image button it shows you the format of [img]THEURL[/img]
    better yet
    how do i get to this hose that cools my oil?
      most of the time when you get oil leaking from around/near the oil filter and it isn't the filter...there is an oil pressure switch...very common leak.
      It is easily visible with the oil filter removed (or the intake out...good thing to replace if you upgrade to a6 intake...which you won't cause you already have it )
      I don't know if the ex's come with oil coolers...my a1 LX did not But that image will give you a good idea what to look for...I'd replace the seal on the oil pressure switch regardless since it's pretty common.
      ____
        better yet
        I can't answer that one for you.
          better yet
          you can get them aftermarket, or spend UBBER dollars for one from Honda.
          Here's a link to a thread here talking about 'em
          That is just an adapter that attaches to where the oil filter screws on...it has an outlet that feeds the oil to the cooler (radiator like part) and then back, the oil filter then attaches onto this unit to filter the oil. I'm not listing the order of flow mind you just generic parts list...very generic
          ____
            6 bucks from honda but i didnt want to wait
            which i wound up waiting anyway cause i cant physically get to the hose
            so i bought some generic 5/8" by the foot and I can only seem to get the oil filter side of the hose off and no idea how to get to the other..
              i think oil rings could be the rpomblem there main job is too trap the oil in the piston chambers
              VS
              Mercyboy: I rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
              MERCYBOY THREAD:http://www.cb7tuner.com/vbb/showthread.php?t=158241
              1990 RHD Honda accord si CB3 Canada http://www.cb7tuner.com/vbb/showthread.php?t=196287
              MY CB7 ON YOUTUBE: http://www.youtube.com/watch?v=CJID_IxwiNY
