If I take the cat off my car and install a straight pipe or a high flow cat will give me any performance or will it just make my car loud. I dont want my car lound so this is why I ask any help or suggestions Thanks
Cat delete
My friend runs a test pipe at the track ONLY. His car normally sounds great. With the test pipe, it sounds like shit... and smells just as bad. If you ever want to run a test pipe, do it for track use only. Run the cat on the street.
Plus, we all have to breathe this air. There are plenty of idiots out there polluting our environment. We don't need to add to their ranks.
If you want a "high flow" cat that actually works, pick one up from www.sms-products.com
Otherwise, the stock cat works fine. Mikey, you could very well be losing power to that resonator over your cat.
The smell will kill you if you delete it, when i had my header-to-downpipe leak, i was getting alot of headaches and had to always have my windows rolled down, granted this is not a leak that will roll into the cocpit, it smells terrible, along with the loud rassssssp...
_____________________________________________
2 year ASE Certification/Auto Technician Degree completed
Originally posted by eazyduzit509 View PostThe smell will kill you if you delete it, when i had my header-to-downpipe leak, i was getting alot of headaches and had to always have my windows rolled down, granted this is not a leak that will roll into the cocpit, it smells terrible, along with the loud rassssssp...
