Turn signal and brake light....need help
    my turn signals and brake lights not working i checked the fuse and its ok what else can it be?
    help anyone
      Well, since they're independent systems, did you check all the fuses? Does it make the clicking noise when you turn on the turn signal? Do the hazard flashers work? Have you checked the bulbs? Have you looked at the brake pedal to ascertain if the switch is still attached or is hanging down, broken off? Did you check the fuses under the hood as well as in the kick panel? Have you opened the trunk and made sure the wires and connections in there are still good?
        yea the connections are good,the fuses are good,i tested for power at the brake switch and have now power but the fuse is good its weird unless i hav a wire short somwhere....as for turn signals,fuses are good and hazards work,only thing its missing the front bumper signal lights,but my signals should still work theyl just be flashing fast
          it could be that because of your front bumper signal light is missing that's the reason why its not blinking. i had a same problem but i was missing my right side bumper lights. one of my wire ripped so it didn't blink when i hit the signal to the right. after i solder the wire back up the signal work. hope this help
          Mrs. Reddy
          http://www.cb7tuner.com/vbb/showthread.php?t=178119
          MY FOR SALE THREAD CLICK LINK ON TOP
