ecu question
    ecu question
    ok i have a 91 cb7 2.2 sohc ecu and i was told to get a p06 well i got this ecu 37820-p06-a02 its not chipped will i have any problems with it on the race track and what the benifit to this ecu?
    You'll need it chipped and tuned.
      The p06 is only going to help you after it's been chipped and tuned to work with your specific engine. Which engine and ECU do you have currently? f22a1,4 or 6 and pt3, pt6 or p12?
        ecu
        f22a1 sohc with a pt3
          Then you're probably running the f22a1 or f22a4. Do you have any mods at all done to the car yet? There are several things you can do to get more power besides having the ecu chipped and tuned. Start here: http://www.cb7tuner.com/vbb/showthread.php?t=88154
            ecu
            the cars not chipped at all and yeah i printed that list out and im currently locating the intake and tb right now its has a headder and msd coil cap rotor 10.5 mm wiresand iridduim plugs as well the msd box is on its way the car is being built 4 a 3/8 dirt track its a real race car with complet roll cage
              ecu
              was also told to ckeck in to web racing cams going to order one next week
                order a cam from bisimoto. his cams are specifically tailored to the f22a engine and are manufactured by webcams
                member ride thread
                DIVULGE MOTORSPORTS
                  And if you cant afford that, ive had a good experiance with my Delta 272, but Bisi's the way to go for top power gain.
                  _____________________________________________
                  2 year ASE Certification/Auto Technician Degree completed
                    Delta is a good cheap alternative, though Bisimoto is considerably better.
                    But yes, the P06 is a stock Civic ECU. Made to run a 1.5L engine. The ONLY reason why it is good for our cars is that it's easily modifiable, and it plugs right up to our wiring. Since the Accord and Prelude ECUs can't be modified, we have to use Civic and Integra ECUs.
                    The only stock ECU that will give you any gains whatsoever is the P12 from the Prelude S. It has the F22A1 in it, identical to the F22A1 in the CB7. The only differences are the intake and exhaust piping (manifolds are the same), and that ECU... and 10 horsepower. Expect to gain 5-7whp from the P12 ECU on a bone stock F22A1. That's the ONLY bolt-on power you're going to get from any ECU.
                      ecu-chip
                      ok thanks for all that info but as far as the chip what brand do you guys think might be best for my app?
                        I hope you're not expecting to just purchase a generic tune... that's not how it works.
                        The brand doesn't really matter. Just get one that's quality. You're going to need to get it properly tuned.
