What's the diffrence in LX, EX and SE models for the o2 sensor. I purchased a header for my SE and it had two o2 sensor openings one in the front and one in the bottom near the cat and I havent installed it but I dont see an o2 sensor in the front only in the bottom maybe I am wrong and I didnt see it. I had a LX like 5 years ago and im pretty sure it had one in the front. Can somebody help Thanks
o2 sensor in 91 SE
What's the difference in the engines? The F22A1 has 125hp, the F22A4 is identical aside from the exhaust manifold, and it makes 130hp, and the F22A6 has a different camshaft, intake manifold, exhaust manifold, and a few other parts... and makes 140hp.
There is no difference in the o2 sensors, other than the location.
The header should have come with a plug. If it didn't, search online for an o2 sensor bung plug.
Originally posted by Lakersfan24 View PostWhat cb has the f22a6? Year, EX, LX, DX, SE I would think it would be the EX but I dont know.
1990-1991 EX = F22a4 ( 130hp )
1992-1993 EX = F22a6 ( 140hp )
1991/1993 SE = F22a6 ( 140hp )
You have an f22a6 ( well you should )
the o2 sensor wires are different lengths...dunno of any construction difference between them, haven't hear of any, the only difference I know of is wire length...at the stealership...well my local one, they charge more for one than the other.
the ex has longer wires as it is located further down the manifold, the le has shorter wires as it's located higher up on the manifold..____
Originally posted by Lakersfan24 View PostThanks for the help, now a diffrent question on the FF22A6 should I still sawp for a H23 IM and TB or what could I do for faster acceleration
Originally posted by Lakersfan24 View PostThanks, so what would I use to plug it, a bolt with a gasket or something like that. So whats the diffrence in the engines is one better that the other?
Your car should have it in the lower mounting location.
Originally posted by Deetz View PostHave you ever seen a dyno showing that swapping that intake manifold actually make more power? Just curious.....
When I double stacked mine with the H23 plenum and tb, I could definitely feel the difference in the low end.
Originally posted by Lakersfan24 View PostWhen you say runners do you mean the holes that are inside when you remove the TB? because I changed the gasket to that last week and it had 8 holes for in fron four on the back like this 0000
0000
Originally posted by Lakersfan24 View PostSo those that all just bolt right on or do I have to mod anything any sensors or anything that I have to buy extra and how much does something like that run. Thanks
