cam gear
    cam gear
    has anyone use adjustable cam gear from tazauto the 75 dollar one an dis any good
    thanks steve
    i had one on my eg it was cool but you have to cut your timing cover to make it acsesable works good dont know about the brand i would stay away from cheap one though ive heard of the cheap ones comming loose and then you lose your motor
      cam gear
      so i think im going with aem gear and a cam gear on stock cam does it help in any way
        depends have you read up on it if not you should. lol im not bashing you its just you can damage your engine depending on how much adjustment and what you distrbutor is at. the cam gear let you adjust you cam timing good for gains in top end
          You've decided you're going to get it, but you don't even know what it does? That's a really smart way to modify your car...
          Bisimoto makes the best one on the market. AEM is good. TASauto has good products, but I don't know anything about their cam gear in particular, so I can only go on the reputation of the company itself.
          With an adjustable cam gear, you can move the powerband. It is most useful with an upgraded camshaft, and even more useful with head work. On a stock engine, you won't see much of a gain. You really shouldn't mess with it unless you know what you're doing, and it should be done on a dyno, so you can measure the results and set it where it will actually be helping you, rather than hurting you.
          If you adjust it improperly, you could damage your engine.
            =2 see great minds think alike lol but seriously do some reading
              I saw an arm one on eBay for 120 and a skunk 2 for 100 if you still want to get one just cause
