Feels like I'm driving on air.
    Originally posted by nightime25 View Post
    I did have the PS pump off due to swapping in a engine so more then likely there is air in there. I will inspect everything tomorrow and get back with my findings.
    IMO (based on limited knowledge) If you have followed the usual procedure for bleeding the air out of the system, which is simply to put the front end up, start the car, and turn the steering wheel from lock to lock 5 or 6 times, then I doubt there is air in the pump itself. Given that the power steering system is under high pressure while in operation, it seems unlikely that air could leak into the system even if you have a leak someplace . Air *could* leak in to the system someplace if you have a serious leak such that it leaks even when the car is turned off and the system isn't under pressure. But then what would happen is you might experience a short bout of "harder steering", not a "free floating steering".
    Good luck with the investigations.
      Alright, there is no more "Free floating steering" going on. The wheel still shakes and then smooths back out so going to get the wheels rebalanced. However, there is some serious clunking going on, and for the life of me can't pin point the culprit. I've inspected everthing and everythings tight.
      I did buy the skunk2 struts/springs and would anyone no when the strut is compressed completely how fast should it pop back up? and should you be able to compress it by hand fairly easily?
