Please Help...clutch Pressure Problem
    I Have An H23 And Having Problems With The Clutch Master And Slave Cylinder I Replaced Both And Also Replaced The Whole Line From The Master To The Slave And Bleed The System And Still Having Problems With The Pressure I Get Very Little Pressure Not Enough To Shift The Gears Only Way I Can Shift Is At 2 Gran Without The Clutch Only Other Thing I Can Thing Of Is That One Of The Slave Or Clutch Master That I Baught Are Probly Bad Since I Baught Them At Discount Auto Parts And There Parts Are Rebuit.....please Help Any Other Segestions Or Tips Please Help...
    Holy crap... I can't even read that. Please don't type in all capitals, and please use punctuation. If we can't understand you, we can't help you.
    I assume you're saying you bled your system and you still don't have pressure. The cylinders MAY be bad, but chances are you just didn't bleed it completely. I'm having a similar problem, and I'm about to have my car towed to the dealership so my friend can fix it for me.
    If you didn't bench bleed the new cylinders, it may take a while.
      ok ...whats bench bleed?
        Filling it with fluid before attachng it to the lines.
          i dont think thats the problem,cause i bled it for like an hr
            this system is a pain to bleed...and if you don't bench bleed the master cylinder, then it is even that much harder...but before you try that...try to do a gravity bleed first by opening the bleed screw and keeping the reservoir full...most of the time this will work just fine...keep an eye on the bleed valve and when all the air bubbles stop then check it...this may take awhile...but it is effective...or you could buy yourself a pressure bleeder...that works the best...good luck
            "I can imagine no more rewarding a career. And any man who may be asked in this century what he did to make his life worthwhile, I think I can respond with a good deal of pride and satisfaction: 'I served in the United States Navy." --President John F. Kennedy
            ASE Master Automotive Technician
            ASE Master Med/Heavy Truck Technician
            US Navy Electrician
            Contact me if you need help on the side.
            '92 Accord DX (For Sale)
            '01 Civic LX
            '00 Tahoe
            Greatest Rally Video Ever
              u may need to adjust the clutch pedal,
              u can do this by adjusting ur master cylinder
              where it connects to the clutch pedal,
              u prob need to unscrew it further out then
              reattach th pedal back to the master cyl.
              cuz when i did mine i had to adjust it or i culdnt get it
              n gear while the car was running, and it was bled properly...
              hope it helps,
                hope it helps,
                Same for me. When i re did my master and slave cylinder i completely overlooked this step and for the longest time couldn't understand why the clutch engagement was so effed up
                Installing a turbo and planning to tune later is kinda like having sex and planning to put the condom on afterward.
