I Have An H23 And Having Problems With The Clutch Master And Slave Cylinder I Replaced Both And Also Replaced The Whole Line From The Master To The Slave And Bleed The System And Still Having Problems With The Pressure I Get Very Little Pressure Not Enough To Shift The Gears Only Way I Can Shift Is At 2 Gran Without The Clutch Only Other Thing I Can Thing Of Is That One Of The Slave Or Clutch Master That I Baught Are Probly Bad Since I Baught Them At Discount Auto Parts And There Parts Are Rebuit.....please Help Any Other Segestions Or Tips Please Help...
Please Help...clutch Pressure Problem
Holy crap... I can't even read that. Please don't type in all capitals, and please use punctuation. If we can't understand you, we can't help you.
I assume you're saying you bled your system and you still don't have pressure. The cylinders MAY be bad, but chances are you just didn't bleed it completely. I'm having a similar problem, and I'm about to have my car towed to the dealership so my friend can fix it for me.
If you didn't bench bleed the new cylinders, it may take a while.
Originally posted by CB7**33 View Posti dont think thats the problem,cause i bled it for like an hr"I can imagine no more rewarding a career. And any man who may be asked in this century what he did to make his life worthwhile, I think I can respond with a good deal of pride and satisfaction: 'I served in the United States Navy." --President John F. Kennedy
ASE Master Automotive Technician
ASE Master Med/Heavy Truck Technician
US Navy Electrician
Contact me if you need help on the side.
'92 Accord DX (For Sale)
'01 Civic LX
'00 Tahoe
Greatest Rally Video Ever
Originally posted by CB7**33 View PostI Have An H23 And Having Problems With The Clutch Master And Slave Cylinder I Replaced Both And Also Replaced The Whole Line From The Master To The Slave And Bleed The System And Still Having Problems With The Pressure I Get Very Little Pressure Not Enough To Shift The Gears Only Way I Can Shift Is At 2 Gran Without The Clutch Only Other Thing I Can Thing Of Is That One Of The Slave Or Clutch Master That I Baught Are Probly Bad Since I Baught Them At Discount Auto Parts And There Parts Are Rebuit.....please Help Any Other Segestions Or Tips Please Help...
u may need to adjust the clutch pedal,
u can do this by adjusting ur master cylinder
where it connects to the clutch pedal,
u prob need to unscrew it further out then
reattach th pedal back to the master cyl.
cuz when i did mine i had to adjust it or i culdnt get it
n gear while the car was running, and it was bled properly...
hope it helps,
hope it helps,Originally posted by deevergoteInstalling a turbo and planning to tune later is kinda like having sex and planning to put the condom on afterward.
