I was looking around and I couldn't find a diagram of how to remove the front shocks from the Accord. Does anyone know how I can find a DIY or something similar?
Removing Struts/Shocks From CB7
You should be able to find a DIY using the search bar (3rd from right on the gray bar on top of the screen).
If you're also removing the springs with a spring compressor, make sure to learn about how to do that safely as it can be very dangerous if not done with proper precautions. Keep the spring ends facing away from your body at all times when it is compressed. They are strong enough to hold a car up so if they get free they will do very bad things to the human body.
Also, the whole assembly is somewhat heavy and awkward so it helps (though is not probably essential) to have someone to help lift it back up when reinstalling.
The process is not hard or really that technical.
Try using Youtube to get a general visual of the process first.Last edited by batever; 03-19-2010, 09:53 PM.
