Well, to make it short, I'm having trouble with the white and green wire that goes into the alternator regulator socket.
I've already replaced in the Alt, the bearings, the brushes, the stator, the rotor and the regulator, I mean it's fully rebuilt.
So I went to the manual and tested it, and to my surprise the S terminal does not have voltage.
The manual says it could be an open in the wire or fuse number 21 blown, but that fuse it's not used, so?
According to the manual it should throw voltage, but it doesn't, then I go following the wire and in the middle, under the TB it throws half of the voltage.
i'm tired and testing that is a bitch, any sugestions what could it be? what can i do?
