h22 vtec killer cams
    im looking for the toda vtec killer cams on the civics. are there any vtec killer cams for an h22. all i seen is for the b16
    我愛我的本田
    Not that I've seen
    http://www.cb7tuner.com/vbb/showthre...=1#post1823428
    My Custom BB6 Dash Swap Thread
      is there any company that makes cams like that. looked all over. i like the sound it produces
      我愛我的本田
        I can be wrong But I don't think they make them for the H22
        Accord Of The Month January 09
        Accord Of The Year 09
        My 2 Babys
        BMW TECH FOR 15 YEARS
          What's your need for them?
          They really aren't well suited for street use, nor drag racing. If you're using it solely for road racing, that doesn't allow vtec, then go for it.
          But, your rockers will suffer, your low end power will suffer, and your idle will be all over the place.
            You've made your decision solely on the sound it makes?
              lol, not always the best way to choose upgrades. Upgrade your stereo system based on the sound it makes, not your performance parts.
              I don't know that Toda supports anything other than Civics and Integras do they?
                I thought they were a B-series company. lol
                Crane makes vtec killer cams as well, but I'm not sure what motors they work with.
                The only true benefit of the cams is to have less weight in the valvetrain, which means you'll have more control in higher RPMs.
                  I know the ones that you're talking about and like they said, not well suited for the street. They are bad ass in their own way but not for the street. Not very well mannered. They are more of a purpose built cam. Bisi is prob one of the best cams you can get for your H motor.
                  click to see my ride
                  click to check out my bb6 dash swap
                    All a VTEC killer cam does is make a VTEC camshaft into a non-VTEC camshaft. One cam profile... and a wild one at that. What's the point? It sounds "cool" because it has a lopey idle. Which basically means it will SUCK in a reasonable RPM range for a street car.
                      Solution: Disable your vtec.
                        Or enable it ALL the time (which would probably sound like a VTEC killer cam)
                        Putting parts on your car without regard to their function is lame.
                          you dont need vtec killer cams to sound like that. you just need a 272 or stage 2 cam and get the idle low.
