Hello, i just went to the JY and i came across some like new Tokico shocks, it comes with the spring already but not sure if its the stock spring... although the spring looks fairly new also. anyways, what can i pair these nice blue hp tokico's with? (springs i mean) thanks for all your help in advance
Pairing Struts and Springs
Any spring that is made for your car. Read here for reviews.
http://www.cb7tuner.com/vbb/showthread.php?t=1003
Certain struts are made to withstand certain spring rates. Just because it fits the car doesn't mean it's right. It seems to me that the OP has a better idea of this than anyone helping him at the moment.
Chances are, the ones you found are Tokico HP (blues), right? They're good for a spring that's about 15% stiffer than stock. If the springs are plain and black, they may be OEM. Aftermarket springs are usually colored. Some are black, but the common ones are often red, yellow, green, blue, etc... Most lowering springs have a spring rate higher than 15% over stock. The only ones that will work properly with those almost stock-replacement shocks (if my assumption is correct) would be springs that are close to stock themselves. Usually .5" drop or less.
Originally posted by deevergote View PostCertain struts are made to withstand certain spring rates. Just because it fits the car doesn't mean it's right. It seems to me that the OP has a better idea of this than anyone helping him at the moment.
yes, i did pick up the Tokico Hp (blues) and i went to see if i saw any markings on the springs and i found out that they are some eibach springs... so i called the eibach company and gave them the part # and it costs over $200 for the springs alone... yay! i GOT A DEAL! anyhow, is this a good pair for a good not so rough ride? does anyone have pics with this setup or similar? i just wanna see how my car will stance out...
Originally posted by deevergote View PostThe only ones that will work properly with those almost stock-replacement shocks (if my assumption is correct) would be springs that are close to stock themselves. Usually .5" drop or less.
