mine still works fine. i have owned mine sine 97 and the light has gone on 3 times. last time was about a month ago.
Low Gas Light?
Originally posted by 4thgentuner View Postu top it off till it spills out??
i culdnt get more than 14 n mine...
When I'm on E, I have about 3.5-4 gallons left in the tank. I don't know if my light's still working or not, I haven't paid attention to it for about a year, but it used to work fine. If I get in the car and the needle is low, I stop and fuel up.
Originally posted by 19dabeast85 View PostI've swapped 4-5 different clusters into my car for various other reason and the low fuel light has never worked, I assume the sender in the tank is bad.
Originally posted by cvc7chris View Postwanna revive this thread, my dd cb7's low fuel light isn't working...anyones got a fix for this? maybe the sender in the fuel pump? or what...
unlike the fuel pump, which does not have an access hole in the trunkLast edited by KB7; 05-17-2010, 01:22 AM._
Originally posted by mercyboy View Postwell it could be the light. or it could be the miss sensor or wiring....
But seriously... the best car on earth is a woman, it only needs 5ml per ride full equip... 2 air bags, it starts by a finger... you dont even need a license to ride it! You can get in front or at the back, no need for an oil change!?!? it does it by itself each month
Back to the tread... i never experienced it as i always fill it up when i hit 1/4 of the tank. I should try and see if i got the same problem one day :P
