Tachometer is not working
    Hey guys. I recently bought a 90 lx with 95xxx on it. Love the car so far, this is my dd right now. The guy who I bought it from claimed it has a new clutch so i assume that who ever did the clutch job didn't connect the tach back on. I have searched and remember a lot of people said theres a plug with a blue wire but i couldn't find it anywhere. My tach doesn't work at all. Its not jumping up and down, it stays stopped. Is there a connection behind the instrument cluster?
    it has nothing to do with the clutch job. If your ECU was not getting a RPM reading it would not start.
    Is there a check engine light? If so check the blue wire from the distributor to the ECU. if there is no check engine light you need to check the connection from where the RPM signal splices into two... half to the ECU the other half to the cluster. If that checks good then your cluster is broken. If its bad you need to fix the wiring between the ecu/splice and the cluster. simple as that
    member ride thread
    DIVULGE MOTORSPORTS
      No CEL here. Car starts and drive great. Anyways, i'd do what you've said again tom when there's day light. Hopefully its something small and i don't have to replace my cluster. I don't think i can find any used cluster with 95xxx around here or withn 10000 miles of my cluster.
        Just get a used cluster and swap the tach out of it. U don't need the rest of it so u can keep ur cluster with ur mileage. Or u could get a used cluster and just roll back the mileage on it. Not too hard, done it many times.
          verify the wiring before you jump to a cluster issue.
          member ride thread
          DIVULGE MOTORSPORTS
