I have a 91 accord auto trans. it has a sports mode light. (s) light will not stop blinking, already changed the tcm. What else can be the problem?
S mode light
Originally posted by 91_honda_CB7ben View PostI have a 91 accord auto trans. it has a sports mode light. (s) light will not stop blinking, already changed the tcm. What else can be the problem?
Take it apart, clean it up and add new dielectric grease, or go to the junkyard and grab a replacement.
If it is, do what Konigstiger mentioned.
Check the code first, before you go disassembling your car. There's no need to take things apart until you know what the problem is. The blinking light is indication that your TCM is WORKING (there was probably no need to change it). It's an indication of an error code regarding some other function of your transmission. VSS, shift solenoid, etc...
