4800 rev limiter no CEL
    Just wondering if anyone has an answer for this...
    Car cannot go past 4800rpms, we have replaced the ECU (with a chipped P13 and auto poa) without prevail. Replaced coolant sensors because when you near 4800 the temp gauage will go all the way to cold and comes back up once you're back at normal rpms. The CEL light bulb works but never throws a code for this problem.
    Car has very bad fuel cuts when you let off in 2nd gear, starts to jerk even with brand new engine mounts! I believe its a coolant and fuel problem.
    Any ideas?
    No fat dudes, car will scrape. Katie
    wierd... I would check all the vacuum lines too make sure they are all plugged in correctly..
    just my 2 cents
    My ride
    http://www.cb7tuner.com/vbb/showthread.php?t=154423
      if i remember you have CD5, vtec?
        Yes with a f22b1
          your temperature gauge drops at high rpms? (highway driving...should be the only way it drops..) in that case i would replace my thermostat and bleed my coolant system..to start...
          as for the jerky cutting out, well i would need more info to even begin to help you, but im no pro by any means
          any more info you could add or things you have done to try to fix the problem would help others to help you
