how to change the back arm
    Ok I got a bent rear arm the piece that's holds the disc and shocks and everything else in place. I think its called the sway bar. Now the question is would I have to get it off a car that is the same as mine. The reason being is cause I haven't been able to find one that is disc. I've only been able to find the ones wit the drums. Can I just take off the hub and replace wit my disc or would I have to modifie it to fit.if u can help that would be really helpful thanks
    We can't help you unless you're sure about what the part in question is. Many suspension components are supposed to have a bend in them to get around other objects. Your best bet is to take a picture of the part you're worried about and post it up so we can actually see.....you'll get much better response to almost any topic if you have pics or video. If you don't have a camera, go on hondapartdeals.com and find the component that's bent and let us know.
    My Member's Ride Thread
      Maybe but I think he just needs to know whether the rear sway arm is the same for drum and disc models so he can swap in a used one from a CB7 that has rear drum brakes on his disc brake DX. I am assuming he knows the swayarm is bent because of a collision or something.
      Anyone know if the rear swaybar on the disc brake CB7 is the same as on the drum brake CB7?
      OP, look up the posts on rear disc brake swaps. They will outline what parts need to be changed when adding rear disc brakes to a drum brake model cb7. I'm guessing that the rear swayarm is different between the disc and drum models because they will need mounting holes on them for the calipers. But check the disc brake swap howtos and the info should be in there.
        Yea its my swayarm. That's bent the guy I bought the car off told me that he hit a curve at a angal and bent it. So now my tire gets worned out fast and I just want to change it
          Drum brake and disc brake rear sway bars are the same. They connect to the trailing arm so there is no reason for it to be diffrent.
          Sounds like you need an alignment. A bent sway bar means there is probaly somthing else bent down there too.
            thanks a lot man ill go get one tomorrow
