sputtering idle
    sputtering idle
    ok i strarted my car for the first time since january. since then i've changed to a h23 mani with h22 tb with egr block off and fitv block off plates. i've also added a catch can on the pcv line. it took a bit to start but when it did the idle was sputtery and it doesnt sound too good in throttle. ecu was changed from pt3 to pt6. tried both, same problem. could this be from the block off plates? or do you think i need to reset my idle? any help would be greatly appreciated
    2013 Ice Cream Cruise!
    VIDEO: 2012 Ice Cream Cruise
    VIDEO: 2012 Ice Cream Cruise part 2
    The single largest cruise in the Midwest!
    August 3 ~ Omaha, NE
    By 1320 Video
    Member's Ride Thread
    Reset your idle.
    Put good gas in your car (this is 2-3 month old gas you're running now, I assume)
    And honestly... the block off plates don't really do anything good. Put things back together the way they're supposed to work.
