Shit Box Won't Start!
    Long story short when you turn the key it doesnt make a sound. No clicking or anything. I checked the battery and all my ground connections. Radio will not come on also. I checked Fuse box under hood and found, ignition fuse was blown(50amp), and interior light fuse was blown(15amp). Any suggestions?
    Tap the starter.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      Originally posted by Konigstiger View Post
      Tap the starter.
      Tried that, but the fuse blows as soon as i turn the key.
        ur ignition fuse is blown then its not sending power to any thing.replace it.ur radio not workin is the other fuse and the ignition fuse replace both and ur car will be good.
        my new turbo build
          So every ignition fuse you replace blows everytime you turn it on?
            I replaced both fuses and when i tried to start it they both blew. . . I'm tryn not to go through anymore fuses cus the ignition fuse is not cheap lol
              Then you got a short somewhere y0! Possibly a rat chewed the fugg out of a wire.
                well that makes more sense then the first post.well u have a short my friend.also check ur grounds.and ur fuse box might be takin a shit.
                my new turbo build
                  Damn thats what i was guessing just wanted a second opinion. . well back too pulling wires fml. I hate rats lol
                    I had a rat living on my previous CB , partially ate my positive wire.
                    Thank God , I wasn't lit on fire.
                      How exactly does ur fuse box take a shit??
                        Last person i knew who had a mouse in their car they crashed into a pole. It was an epic day.
                          the connections inside go bad and melt get black and eventully just stop sending current or send it throught a different route and short out.
                          my new turbo build
                            Wouldn't that cause everything in the fuse box to take a dump?
                              sometimes yes and no there are tons of componets in there.is like an amplifire you can blow 1 channel and still have 2 or 3 left that work fine.
                              my new turbo build
