i was wondering how hard is it to change the driver side door on a 93 lx any help will be good i will appreciate it
changing driver side door
I haven't done a front door on a CB yet, but I did my rear door a couple weeks ago. Slightly time consuming, but fairly straight forward.
Basically, start by unscrewing and unclipping your door panel. Remove the door panel and unplug all of the switches. Unplug the wiring harness coming from the car and going to the door. Pop the hinge pin out of the door hinge and then unbolt all 4 bolts holding the door onto the body.
Reinstallation is the reverse procedure.
Originally posted by crazymikey View PostI haven't done a front door on a CB yet, but I did my rear door a couple weeks ago. Slightly time consuming, but fairly straight forward.
Reinstallation is the reverse procedure.Last edited by 92accordkidwife; 03-08-2010, 05:53 PM.
Originally posted by crazymikey View Postprobably just as easy to do the whole doorLast edited by 92accordkidwife; 03-08-2010, 05:54 PM.
