IAB plate Removal and cleaning
    hey guys how can i get the IAB plate out of my H23 mani?
    and whats a good way to clean my mani?
    i was going to soak it in soapy water with some degreaser?.?.?.
    92 LX N/A rust bucket restoration RIP
    91 DX Coupe to 9293 EX Coupe restoration
    funds for swap:$000.00
    Bought from:HondaFan81=My current CB7 DD ,CB7_Sleeper1 Koochologist Tommi mtnbikkerkid33
    Traded with: Wed3k
    come on guys no help?
    and one more thing HOW DO I GET THE IAB PLATE OFF THE RUNNERS?
    is there an easy way without marking up the plate/plenum?
    Traded with: Wed3k
      Hey Mega all you had to do was ask on my thread and I would have told you.
      Anyways your answers for you;
      1. you will need to disconnect all vacuum lines from the plenum, your throttle cable, unplug that sensor on the front of the plenum, disconnect the coolant lines (be prepared to spill some coolant), take off the CAI if you have one or the stock one, and then there are 3 bolts and 2 nuts that you will need to take off with a 12mm socket, and then pull the plenum off. It is all pretty easy.
      2.to clean the manifold you can use some carb cleaner and that will do the trick but if you are cleaning the manifold runners you will need to take them off to do so. I did it this way and mine came out clean.
      Also I wouldn't use water to clean the manifold because then you have the problem of rust occuring. If you can't really read my stuff I am sorry I tired and it is probably not worded all that great just ask me what you need me to clarify and I will.
      Originally posted by 92jdm
      if you have any mechanical inclination, it should be easier than a drunk highschool girl after prom.
        hi hi there is a nut under the cap.. the cap comes off easily with pliers
        clean? remove erg plugs then have it hot tanked it will look like mine
          The plenum and IAB plate will probably be kinda stuck on there so just use a flat head screwdriver to pry them appart. The plenum just grab it by the TB and pull up and it should come loose.
          And don't worry the screwdriver won't hurt it and if there are any little scratches the gaskets will seal those up
            And Teddy is right, hot tanking works wonders too my buddy did that with his H22 parts and they came out clean clean.
              yeah i had planned on hot tanking it i just need to get it ready
              and i will pry it right now then post up thanks guys
              Traded with: Wed3k
                got it
                ok now my question is how do i get the diaphram off the IAB plate?
                Traded with: Wed3k
                  I believe the diaphram is part of the butterfly rod. After you remove the cap on one end (theres a screw under it), and you individually remove each butterfly plate, it should slide out if remember correctly.
                    Remove the butterfly valves with a philips screw driver, then just remove them.
                    Simple as that, you get more velocity without them, just to let you know.
                      For a unboosted vehicle, its best to keep the iab system functional unless your running a heavily modified motor that your reving over 7k, then it might be best to remove them, as they could become a restriction at those revs. Functional IABs help with retaining torque in the low end, which is especially useful for typical daily driving scenarios.
                        i know i lose velocity with them, but i plan on boost pressure to be up enough to compensate by the time they need to open
                        that is a part of how i am going to tune it
                        Traded with: Wed3k
                          boost pressure is usually obtained at about 2500 rpm so opening them when i hit about 2900-3200 rpms would get me past the low end torque problem because the boost curve starts to take off.
                          z
                          one more thing i am getting a 70mm tb port matched to plenum
                          Traded with: Wed3k
