f22a1 rod and main bearings?
    i was taking the crank protector off today and when i did the main bearings came out with it. are they suppose to do it or what? is there a certain way to take the rod bearings out or what? any info will help. thanks
    Are you replacing rod and main bearings? The main bearing protector holds the bearings so they will most likely fall out, just be careful. Im guessing your trying to replace rod bearings, I would keep the main protector on and try to loosen the rod bolts through the cracks, thats how i did it on my H22 it could be different on f22. After that loosen the main bolts and carefuly remove crank to get to the topside of rod bearings. Theres a notch on each of the bearings so you really cant go wrong in replacing them.
      thanks for the help man but the motor is shot...one of the rod bearings are in pieces and the main bearings warped the crank badly. so i guess i just have to get a new motor...this is the second time this has happened...
        Wow terrible luck, I know people have found some dirt cheap f22's out there. With the money you'd spend fixing the crank and buying bearings to fit your fail motor you might as well drop a different engine in. while your at it might as well drop a f22a6 for a slight upgrade or go big with h22. Its all up to you though.
          yea im looking at an h22 sir on ebay so im trying to sell stuff to get it. if your interested in accord parts pm me
