idle problem
    idle problem
    iv looked an read the idle problem reving up an down thread, iv done that tightend the white cap still does it is there any other part i can check??
    can a fuel injector cause this?? because i got a flat head an put it on all 4 injectors, 3 had its clicking noise an one would click when i push to rev up an stops after i reved motor??
    any suggestions?
    usually a revving up and down is a motor that gets too much air aka vacuum leak. the only possible way it could be fuel related would be a faulty injector driver. i rarely see an ecu fail from lack of injector driver.
    there's an idle adjustment screw on the throttle body. check if that has backed out which is very common
      oh alright then im about to go check up on that right now.....
