vtec help..
    vtec help..
    got a 92 accord wit the f22b1 vtec in it. everything swapped in perfect. runs awesome i have right ecu and everything. but vtec is being a pain for some reason. when car is cold vtec cracks great but after car warms up doesn't work worth a crap. sometimes throws a code. i check it and its my vtec. i put different vtec cylinoid on it still does same thing. check all wiring but stil same thing.. idk what to do. only when car warms up it doesn't work its dead sometimes works like a short but i don't see how. any help??
    VTEC shouldn't work when the engine is cold. Additionally, the F22B1 VTEC shouldn't "crack" at all... it should barely be noticeable, because... well... it really does very little.
    Double check your wiring. Be sure all codes are cleared, and all problems that caused the codes are taken care of. Be sure your oil pressure is right, because VTEC is dependant on oil pressure.
    Typing a bit more clearly would help us understand you much better... thus allowing us to help with your problem. You are very difficult to understand.
      sorry bout that. But yeah its werid when engine is cold vtec works great, after warm vtec cuts out or doesn't work at all. i've double checked my wiring, how do i go about checking my oil pressure?
