Hi,
I work for a restoration shop in NJ, and one of the guys in the neighborhood brought by his 90 accord because he couldn't get it started. Apparently the water pump seized, and the pulley shattered. I believe its an f22A engine. Im going to be honest I know about American V8's and Ive done a timing belt on the 2.3 ford, but this Honda is confusing me. I got it all apart to today the balancer bolt was a nightmare but I think you guys all know that lol. I have the cam lined up, the 2 bars on the cam gear are lined up even with the head, and the balancer was at TDC when I took all the covers off. The problem I have is the 2nd smaller belt I guess goes to the balance shaft. It was mangled and is most likely out of time, How do I line that up to get it timed right. From what I read online there a bolt hole some where on the block that you put a bolt in and some how it helps you set it? I know you can just take the shaft out but its a customers car so I cant just make that decision. I'd like to go in there tomorrow and finish this car up for the poor guy, please help me out.
