when I drive the car hesitates/bucks mostly 2k to 3k also if I floor it it bucks almost like if I go by redline nd let off the gas real fast then step on it again can someone help me idk why it's doing this I swaped the h23 Im on it also feels like a miss but it's not missing I pulled every plug out one by one I had a little bit of oil in the chambers cleaned it out I have the f22 injectors like it says all the wires are pretty new
2k to 3k problems
2k to 3k problems
http://www.cb7tuner.com/vbb/showthread.php?t=138029 <-mrt
diy whore riiittteeee here
[URL="http://www.cb7tuner.com/vbb/showthread.php?p=2208455"]
http://www.b20vtec.com/forums/members/pr3pg4lyfe.html
Verify your TPS is correctly set.
member ride thread
DIVULGE MOTORSPORTS
how do i do that there arent bolts or screws on the tps sensor?? its like rivited on or something.http://www.cb7tuner.com/vbb/showthread.php?t=138029 <-mrt
just read it should be .45 close throttle 4.5 wot and on the connector it should be a steady 5v is this correct??http://www.cb7tuner.com/vbb/showthread.php?t=138029 <-mrt
dont think it could be ig timing cuz i havent touched the dizzy. ill check tps. aslo had a cel for wts or cts changed it. would low coolant be a problem??http://www.cb7tuner.com/vbb/showthread.php?t=138029 <-mrt
Mine does something similar. I swapped in a richer fuel map (chipped P28 running my H22) and it fixed the problem somewhat. Well, masked it. I know it didn't fix anything. But more fuel seemed to solve it somewhat.
That had me thinking it was an oxygen sensor issue. I also got Code 43 (fuel supply system), which is often indicative of the oxygen sensor as well.
I don't know for certain that the o2 sensor is the problem with my car, but that was my first thought. Your symptoms sound awfully similar to mine.
