Which rear motor mount do i buy?
    I just want to make sure i buy the right one.
    1990 dx automatic
    http://sd.autohausaz.com/autohausaz/...Engine%20Mount
    Thanks for your help
    http://www.cardomain.com/ride/2620526 190E Mercedes Benz
    http://www.cardomain.com/ride/3065882 Accord Under major Repairs
    Your link doesn't go anywhere.
    You don't buy the oil filled mount that comes on the EX models. The LX/DX mount (for the F22A1) is the one you want.
      Deev, my 10th anniversary (LXA) had the oil filled mount, are you sure the regular LX and DX didn't have it also? I had the understanding that all the autos got the fluid filled mount.
      OP: Look behind your intake manifold on the firewall. Is there a small switch that was a 2-wire harness coming straight to it from the passenger side, AND has a vacuum line from the intake plenum to that switch, AND another vacuum line from the switch down to the rear motor mount?
      My Member's Ride Thread
        If you have the mount with the solenoid valve on it the part number is 8984 $63.99 and if you have the mount without the solenoid valve the part number is 8011 $83.99 at Advance Auto Parts.
        How hard do you have to squeeze a baby to make baby oil?
        H23 motor-H22 trans
        Advance Auto Parts Retail Parts
          i too believe that most, if not all, auto's have the mount with the vacuum line and solenoid. when i helped adam (mndude07) do his auto-5spd swap, his car had it and its a DX and is one of the most factory-option-deprived accords i've ever seen.
            If you have an automatic, you have the oil filled mount, with hoses running to it. (95% sure on this, if I'm wrong, please correct me). However, it would be smart to buy a dx/lx non-auto rear bracket, and use a dx/lx 5spd mount. They are more simple and stronger.
            Past 1990 Accord EX Sedan
            Past 1990 Accord LX Sedan
            Past 1991 Accord LX Sedan
            Past 1993 Accord LX Wagon
            Current 1991 Accord EX Wagon
              I always thought that was an EX-only thing... My lack of hands-on experience with automatic CBs is showing! Sorry if my information is incorrect...
