Blown Head Gasket?
    Ugh head gaskets
    life is good.
      remember when i was thinking or actually was told i had a leaking head gasket...?
      after all the research and feedback determined it wasnt the case
      ended up being a bad intake gasket and coolant was getting in the engine that way
      that was my original gut feeling before i took it to a shop for a second opinion
      well i took everything off to change the gasket, because i needed to get it fixed in a hurry, i ended up just getting a felpro gasket from advanced auto
      never dawned on me that my dual stage intake manifold on my f22a1 motor was that much different than the single stage intake that i am guessing is the what came on it...
      but anyway, bought the gasket and advanced only came up with just the single stage gasket kit, so i bought it installed it...
      got it all back together, ran fine for a couple days and now idles like crap
      kinda felt like i had a vacuum leak or leaking intake gasket, something, but checked and rechecked and couldnt find it...
      researched on line to find other ways to test for leaks like that and found i could use carb cleaner and spray around to find the source...
      found it... bottom side of intake gasket where the original was leaking from...
      when i put the single stage intake gasket i did see that it did not line up perfect but it covered fine around all the holes so thought it was going to be ok
      but i see its not
      f22a1 motor with the dual stage intake that according to the chiltons book came on the f22a6, do i need to worry about that or can i just use the gasket kit for the daul stage and everything will be alright or is there something else i need to do to make sure it doesnt leak anymore?
      talked to deev about it and like i was hoping and wasnt for sure jus use the f22a6 gasket and all will be good
      DailyRuNr
      RTeK72
      www.cb7tuner.com/vbb/showthread.php?t=171103
      B18CA1 and B18B http://pbckt.com/sA.d5W Hoping to get a 90-93 Integra sedan to put one of these in some day...
      http://tipthepizzaguy.com/
