after some extensive research, and talking with others and ur post, and that erie feeling the mechanic i took it to...
took to local shop and had them do compression check and they used the chemical test to check, nothing very noticeable on compression check then mechanic did chem test....
but what was weird, his chemical was already green/yellow before test,
mechanic said cuz was lack of oxygen
and used the hand pump to pull oxygen into chem
and it slowly became blue again
although not as dark blue as seen online,
and performed the chem test on radiator to check for exhaust
and chem slowly became green/yellow again....
cuz i dont have coolant in my oil or oil in my coolant,
and not any noticable steam or the smell of antifreeze coming from exhaust
and the nagging feeling that mechanic was just trying to take me for some cash,
i took the car to work today after letting her sit for a few days to see how she acted...
run pizzas for a living....
before i went to work, i topped off radiator with antifreeze, checked oil level, made a mental note of it all
drove the 30 miles to work, checked levels after i let her sit for a few...
all good
no noticeable steam no sweet odor in exhaust
then 45 minutes later when i finally got a delivery,
went out started the car...
rough idle, then smooths out and runs normal...
seemed like a strong odor of fuel tho, like she was flooding maybe
this issue has been going on for a couple weeks
at first thought was bad gas
everyone was complaining about it in thier cars
got the big bottle of lucas back then and put it in
but still have this issue
last weekend i pulled all the sparkplugs to see how they looked
changed them at the beginning of the year]
ngk iridium ix plugs
the one on the number 3 cylinder was the only one that was odd
it had a slight greenish residue on it
thats what made me think i could have a leaking headgasket
still not for sure
could it be an injector issue
i do have a set of venom injectors laying around out of my old integra gsr motor b18ca1 i wonder if those will fit?
but anyways just getting my thoughts out there about this issue
if you could think of anything it would be greatly appreciatied
and i will do the same for u
had hondas since 93 and been hooked since
i do almost all the work on my cars
done suspension, engine swaps, transmission, clutches, wiring, body work, brakes, axles, man the list goes on
oh yea, lol, ran pizzas from 6pm till 1230am and really couldnt tell if there was a head gasket issue
just the hesitation, bog, rough idle for a few seconds every now and then when i started her up
when i got back home checked the levels again, nothing changed, all good
today sometime i am doing an oil change on her, and gona look at that and see if anything there...
get back with ya on that
till then if any ideas come to mind let me know
thanx everyone
heres the pics of plugs and caps....
oil cap
rad cap
my bad it was number 3 plug not 2 as stated before
number 1 plug
number 2 plug
number 4 plug
no oil in coolant...
no coolant in oil...
loss of coolant but no visible signs of leak...
seems to be steam out of exhaust but not excessive...
checked for bubbles in rad...
nothing very noticable
then placed cap back on and used hose from overflow and used soda bottle and some soap and placed hose into bottle and some bubbles...
took to local shop and had them do compression check and they used the chemical test to check, nothing very noticeable on compression check then mechanic did chem test....but what was weird his chemical was already green/yellow before test, mechanic said cuz was lack of oxygen and used the hand pump to pull oxygen into chem and it slowly became blue again although not as dark blue as seen online, and performed the chem test on radiator to check for exhaust and chem slowly became green/yellow again....
just wondering if it is the head gasket causing coolant loss or the intake...
by the way checked plugs and number two had a green/white crust residue...
not overheating or warm, seems to run normal temp, although after running awhile and then turned off to cool a bit, it starts up and idles sluggish till i give it gas...
the mechanic stuck a guage on the rad and chem on the rad
the shop i took it to is telling aroung $800 to get it fixed, if i had a place of my own to do it would gladly do so, but dont, live in a stinkn apartment and they wont even let you change your oil on their property...
just when i saw his chem alreadly green/yellow before the test i questioned his validity
also on that same plug was some green residue mixed with white....
at times seems to a sweet smell like anti freeze but no puddles....
was hoping it was something simple
but the hestitation issue when starting it again bugs me...
i run pizzas for a major company and the car is turned on and off alot
had plans to lower her and wheels but yesterday found out i have the beginnings of a head gasket leak into number two cylinder and now have to get that fixed first...
started it up today and let it run for awhile and today seems like she is blowing more steam than yesterday...
